SilentKoala
I went through Scotty's thread, followed every instruction exactly, got my unlock key from HTC, unlocked my phone (yes it said ***unlocked*** on the fastboot screen) flashed the amon ra-recovery thingy.
I'm confused about the very last step though; I have the SuperSU.zip on my PC desktop but how do I properly install this on my rezound? I downloaded Apk Installer from the market but it doesn't recognize the .zip file itself as an installable file, I can only look inside it and install the .apk file that is a few directories within the zip. So I installed it but when I ran it, it gave me this error: "There is no SU binary installed, and SuperSU cannot install it. This is a problem!"
I have no idea what this means... when I adb shell it still gives me a $ not a #. Did I not install the SuperSU file properly? (Installing from the market doesn't work either.)
All the info I've googled or search for on other forums just says to install the SuperSU but doesn't provide any actual details. Scotty's thread just says "install zip from sd card(chose your superuser file)" thanks but can you elaborate a little bit, how do you actually do this?
