I have a Samsung Galaxy S 4G
Model SGH-T959V
Firmware Ver. 2.3.6
Baseband Ver. T959VUVKJ6
Kernel Ver. 2.6.35.7-T959VUVKJ6-CL694130
Build Number GINGERBREAD.VUVKJ6
Stock phone has very low system memory. I destroyed my 8gig sd-card trying to create a second partition that the phone could use. My phone was not rooted at the time..I kinda missed that part.
Now I am stuck with an old 2gig sd-card.
I followed instructions to Root the phone with SuperOneClick...successfully. I installed Link2SD on the phone...successfully. I Downloaded Mini Partition Tool to laptop. I created the second partition several ways. Phone could only see a second fat32 Primary partition...it didn't like any of the Ext partitions.
Then I got crazy...I looked around and started to install a bunch of stuff. Some useful, maybe. EX., Superuser, upgraded to Elite, Boot Animations, Boot Animation Shuffle, Titanium Back-up, Rom Manager, Rom Customizer, BusyBox free, AdAway, ZDbox free. I am running ClockworkMod 2.X.X.X
Everything installed ok...but I can't flash anything. From Boot Animation Shuffle, if I install boot animations, it says "installed successfully"...
I try to open zip folders from ROM Manager-- Rom Management--Install ROM from SD card and getError: failed to verify whole-file signature, install aborted.
I have missed something important...
I think I have an oddball Galaxy S 4G...
I am thinking that I am not using the correct Applications.
I know nothing about this, hopefully any answers will be simply explained. Thanks!
Model SGH-T959V
Firmware Ver. 2.3.6
