Root Help rooting a Spanish Milestone?
taboo_
I've been having no end of trouble getting root on my Milestone. I'm running 2.1 (which came out of the box). My config is as follows:
Firmware configuration version:
GAS_EMEA_UCASHLS00RTES_P013
Baseband Version:
3GSMEPU91A_U_91.07.4EI
Baseband Configuration Version:
UCASHLSMR@EMEAB1B805C.0R
I believe the "ES" at the end of the Firmware config number suggests it's a Spanish milestone, the user manual also seems to be in Spanish. Also it came with 2.1 installed out of the box.
I haven't been able to get root yet as I need to downgrade to 2.01. Yet when I use RSDlite it keeps saying "phone is not compatible with multi-interface super-file" and failing.
Anyone know what's going on?
