Root help rooting htc amaze4g
I managed to unlock my bootloader and install clockwork using hasoon2000's allinone program. but since i'm on 2.3.4 I was not able to use the permproot feature. I tried using zergrush oneclick root and that also failed, I get the following error:
C:\Users\PC\Desktop\Zerg rush root>adb wait-for-device
C:\Users\PC\Desktop\Zerg rush root>adb push zergRush /data/local/
1479 KB/s (21215 bytes in 0.014s)
C:\Users\PC\Desktop\Zerg rush root>adb shell chmod 777 /data/local/zergRush
C:\Users\PC\Desktop\Zerg rush root>adb shell rm /data/local/tmp/*sh
C:\Users\PC\Desktop\Zerg rush root>adb shell /data/local/zergRush
[**] Zerg rush - Android 2.2/2.3 local root
[**] (C) 2011 Revolutionary. All rights reserved.
[**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
[+] Found a GingerBread ! 0x00017118[*] Scooting ...[*] Sending 149 zerglings ...[*] Sending 189 zerglings ...
[-] Hellions with BLUE flames !
C:\Users\PC\Desktop\Zerg rush root>adb shell sleep 1
C:\Users\PC\Desktop\Zerg rush root>adb remount
remount failed: Operation not permitted
C:\Users\PC\Desktop\Zerg rush root>adb shell mount -o rw,remount rootfs /
mount: Operation not permitted
C:\Users\PC\Desktop\Zerg rush root>adb shell mount -o remount,suid /dev/block/mm
cblk0p29 /system
C:\Users\PC\Desktop\Zerg rush root>adb shell chmod 4755 /system/bin/sh
Unable to chmod /system/bin/sh: Read-only file system
C:\Users\PC\Desktop\Zerg rush root>adb push ./su /system/bin
failed to copy './su' to '/system/bin/su': Read-only file system
C:\Users\PC\Desktop\Zerg rush root>adb push ./busybox /system/bin
failed to copy './busybox' to '/system/bin/busybox': Read-only file system
Unable to chmod /system/bin: Read-only file system
C:\Users\PC\Desktop\Zerg rush root>adb shell chmod 4755 /system/bin/su
Unable to chmod /system/bin/su: Read-only file system
C:\Users\PC\Desktop\Zerg rush root>adb push ./Superuser.apk /system/app
failed to copy './Superuser.apk' to '/system/app/Superuser.apk': Read-only file
system
C:\Users\PC\Desktop\Zerg rush root>adb install ./androidterm.apk
3939 KB/s (92780 bytes in 0.023s)
pkg: /data/local/tmp/androidterm.apk
Failure [INSTALL_FAILED_ALREADY_EXISTS]
C:\Users\PC\Desktop\Zerg rush root>adb shell sync
C:\Users\PC\Desktop\Zerg rush root>pause
Press any key to continue . . .
I did a quick search on the forums, and learned that i could directly download a img and flash it through clockwork (PH85img.rar) but i don't have a sd card and i can't seem to get clockwork to run a file from the amaze's internal storage.
help would be greatly appreciated.
