Rydsim
Today, with my Samsung Tab A, I have accidentally gotten my tab on bootloop. Although I was expecting it soon, as it is rooted, and I've been doing some crazy operations. Unfortunately, the device does not turn off, but if I do a reset, by pressing all of the buttons, it restarts the device and continues the bootloop. I try to put it in recover mode and safety mode, but after pressing the correct buttons, nothing happens, as it does not turn off. It does not connect to a laptop, or any other means. It is so awkward as well, as I had 100% charge.
Is there anyway how I can recover my device? Or should I just take it to a shop to try to get it fixed. Or just end up buying another device - which is my last resort.
Thank you for reading, any response is very appreciated.
