I need help with my Samsung Galaxy S2 i1900 guys. I cannot access my gallery and anything associated with it (camera, some apps and etc.). When I attempt to open gallery (and others) I receive a pop up that says "SD card is being used as a mass storage device" I didn't drop it or mess with the settings. This problem just came out of nowhere.
More details:
- Occasionally I'll get a notification on the scroll down menu that says "USB storage damaged. It may need reformatting."
- When I connect it to my computer with the USB, the drive doesn't show up on "My Computer" (it usually does). IT DOES HOWEVER show up on my "Devices and Printers" on the "Control Panel" as a connected device.
I already did some researching on Google and found no solution that works. Anyone had this problem before and fixed it? Anyone have any idea how to fix it? I'll reformat or Factory reset if I need to, but I want to see if there are any alternative solutions since I don't want to lose my files. Thanks in advance.
More details:
