Help Help SD Card Not Working After Partition
  • Start date Start date
A
Android Question
Guest
Guys I need urgent help. I created partition of my SD Card using MiniTool Partition Wizard to use it as second partition for the Link2SD. After creating partition my Windows 7 Laptop is not recognizing the MicroSD Card. What should I do. I have already wiped all the data of SD Card and put in on the laptop before creating partition.
I assume you tried to create a ext4 partition. Windows will not recognize ext4 partitions without additional software. Possibly you accidentally formatted the entire card in ext4, so now poor ignorant Windows doesn't recognize the card. Check it out and maybe try re-creating the partitions.
