C celticfc482 Member Nov 5, 2010 #1 I cant take pictured or store anything on my SD card,says something about insufficient file permissions any ideas thanks
C celticfc482 Member Nov 6, 2010 #3 Just to add, it doesnt unmount when i go to that and format is greyed out so dont have a clue really
C celticfc482 Member Nov 6, 2010 #4 Well, just seems to be this card i tried another one and that works, The card says ready only in settings, any idea at all?
Krimian Member Nov 6, 2010 #5 Can you access the SD card when you plug your phone into computer and mouse as disk drive?
C celticfc482 Member Nov 6, 2010 #6 Krimian said: Can you access the SD card when you plug your phone into computer and mouse as disk drive? Click to expand... i couldnt, i ended up fixing it after hours of looking about, thanks anyway
