**Help! Stuck at Vibrant Logo
rsvp214
Hi,
I have been stuck on the white Vibrant and Samsung logo. This is what happened and what I've done:
1. Rooted this over a year and half ago, ended up with issues so re-flashed with Odin to stock.
- Didn't do anything after that except install some theme changing apps. Superuser is still there.
2. Recently, installed 3 fonts to the phone using FontInstaller.
3. The last one that was installed - got installed, and reboot process started, but ended up stuck on the Vibrant logo.
4. Tried to re-flash what feels like 100 different ways... but nothing worked. I can get into Download Mode and Recovery Mode, but everytime I try to re-install packages. It gives me an error [E:Can't open /sdcard/update.zip] Since I can't get pass the Vibrant logo, I can't check if it is there. And probably because I've tried to reflash so many times, Odin does not recognize my phone. My computer makes the sounds for a connect device but nothing shows up.....
Any suggestions or ideas to help get my phone back... or is it bricked beyond repair?? I would appreciate any help. Thanks!
