Root Help stuck in Bootloop
KikkiMom
I have a Samsung Galaxy Gt s5830d phone. I recently tried to upgrade the phone to android 4.3 using cyanmodgen 10.2 and now the phone is stuck in bootloop. What can I do? I have tried to factory reset. I have clockmod revovery installed on my phone. I have wiped cache and davlick.
According to the reviews i have read, the s5830d does not always run the generic s5830 roms, it gets bootloops sometimes.
So, you can either flash a custom rom that you are sure that works for your device, otherwise you can flash a fresh samsung firmware via Odin.
Consult the rom developer with this problem, maybe they can make it more compatible for your device.
