Root HELP Stuck on 1xrtt
I have noticed the other day my phone kept kicking off with no signal.I shut my phone off and restarted it.When it powered on I noticed my phone had no 3g but was at 1x.I have tried everything going into settings in the hidden menu.If anyone can throw me some Ideas I would love it.I still have signal just SOOOOOOO slow.btw Boost Marquee running CT Mod 3.75 nothing special done to it.I tried pushing a new PRL it went through but still the same 1x.I put a pic to show what my status is on it.IDK im stuck.SOMEONE PLEASE HELP lol
Have you done a profile update? If so, did you do a battery pull and leave it out for a few minutes after doing the profile update? If not, try it.
You can always switch to a new prl.
There is also a chance the towers in the area are having trouble.
Here is a post that will give you the info to help you change the prl. You will need to be on a stock based ROM. I use Mark Beats when I changed mine in the past.
http://androidforums.com/showthread.php?p=5449159
Actually I did pull the battery did a profile update and I don't think it' the towers its happening even when I leave town.I updated my perl using Marky beats and restored back to ctmod but same thing is there anyway I go into network setting and into mobile settings and I change it from 1xrtt but it changes back automatically.I even went in the hidden menu maybe some thing was wrong in there but idk what the stock settings are in it.
