Performed s-off wire trick and now my phone is stuck on the juopunet screen with the arrow. Tried to run control bear again and it says that I will have to manually reformat external sd card.
Please help do not know what to do here.
Worked great Scotty.
Flashed gingerbread ruu and was able to grab the ota afterwards, which was why I started the whole s-off process in the first place.
Now to do some searching on how to obtain root access again after the ota.
Scotty can correct me if I'm wrong here...but since you are s-off you should just need to flash a custom recovery and then superuser.
Few threads down.(can't link I'm on phandroid)
Root ota with s off![]()
You'll have to flash it in recovery
