what files are compatable with this phone. when i try to download non market apps it tells me the phone does not support it? with my droid it was apk. files? someone help i have a t mobile G2 touch
.apk files are just fine. What version of Android are you running? If an app is needs Android 2.2 and you are running 2.1 then it will not be compatible. If you are still running 1.5 then more apps will not be compatible.
