Help HELP: Task Manager pops up on 'screen capture'
G2E4GT o/s 2.3: Holding down Home & Power buttons to capture home screen, pops up the task manager just before screen is captured. Thus, you can't see most of the captured screen as task manager is over-layed on top. Batt pulls haven't helped. I do have the task manager shortcut on my home screen. Any help?--all is appreciated.
Well, should have checked before, but found that if the task manger 'shortcut' was removed and/or just replaced with the icon itself, all works as it should. I guess that somehow the 'short cut' was interfering w/ screen capture.
you just have to do it real quickly before the task manager gets a chance to pop up. I thought it was an issue too, but it really isnt as long as you do it fast enough.
