New to the whole tethering thing. I know little about what my phone will do. I have a Nexux s 4g from sprint. How can i use my mobile data plan to surf the internet on my laptop?
For ICS and later, you can tap the "More..." option under "Wireless & Networks" in your general Settings. In there, there's a "Tethering & Portable Hotspots" option.
From there, you can enable USB tethering if you're connected to a computer via USB (you'll have to install the proper driver to get it to work), or you can enable the "Portable Wi-Fi Hotspot" option to turn your phone into a wireless router that shares your data. The Hotspot option is by far the simplest.
On Gingerbread, the same options are there, just in different places. I don't recall where.
