Hi Guys can anyone help me in removing the G icon from the status bar? Please refer the image attached.
Wat Rom are you using?? Sagarwep's??
Try flashing the SystemUI.apk from Mastermind's Anarchy..
ro.gn.operator.showslot=yes
add this to build.prop
if its already there just change it "no"
well its worked for me in default mmx rom
Are u familiar with apk modification using apktool???there's the only way to remove those icons.
After decompiling replace following 2 files in /res/drawable-mdpi with one in my rom's SystemUI or sagarwep's rom's similar files.
1) zzz_stat_sys_signal_3g
2) zzz_stat_sys_signal_g
