Help Help to Playing PokemonGo on CyanogenMod13,
ImNoEvil
3
0
I've Flashed/Installed CyanogenMod13 (6.0.1) on my LG Volt & Xposed, TWRP Recovery as well.
Had minor issues with not being able to move media to SD Card but Used a Xposed Mod Called "XInternalSD"...
Now, I'm trying to figure out how to either install Magisk or from what I hear, Renaming Storage/SU & Storage/xbin on my Device (or something like that) without screwing something up, and if I do infact make a mistake... that I can Restore my TWRP Backup & things be back to normal.
Because I really don't know if changing/renaming internal things like SuperUser will effect my device permanently.
PLUS I'm not sure if by Using the Xposed Module "XinternalSD" (That Basically Granted Permissions to SD Card and/or Mounted SD Card as Primary Storage, will effect any process I attempt whilist Flashing/Installing New Software in order to Play PokémonGo.
BEST TECH IN 2023
Smartphones
