hello to you;
i all started when i rooted my device by superoneclick and i thought that i succeeded. but this job installed superuser app and nothing else or better said it is the log
look at it
Root Access is not properly configured or was not granted.
Super User Applications Status:Superuser application - version 3.1.3 - is installed!
SuperSU application - version 1.00 - is installed!
System File Properties for Root Access:Standard LocationCheck Command: ls -l /system/bin/su:Result: /system/bin/su: No such file or directoryAnalysis: File /system/bin/su does not exist.
Standard LocationCheck Command: ls -l /system/xbin/su:Result: -rwsr-sr-x root root 22228 2012-11-06 17:33
suAnalysis: Setuid attribute present and root user ownership present. Root access is correctlyconfigured for this file!
Executing this file can grant root access!Alternative LocationCheck Command: ls -l /sbin/su:Result: /sbin/su: Permission denied
as it seems we lack sudo and the su file is misplaced in xbin rather than bin or sbin.
i tried really hard but no luck with other method
z4root and unblock and...
i just found this methid too in howtogeek but i am really dont know if it is just for one specific device or all of them.
howtogeek dot com/120482/how-to-root-the-nexus-7-galaxy-nexus-or-neoxus-s/
by the way i need your help.
be kind enough to mention any howto.
IF anyone point my to right direction to find out how to root my device manually i would be thankfull.
look at it
