Help Help! to use my SD card to installed downloaded apps.
doughn
im using HTC wildfire on 2.2.1
is it possible to use my sd card memory space for the installed apps and downloaded apps.
newbie here. any help (step by step) will be highly appreciated. thanks in advance
-doughn
First of all, welcome to these forums. Second: not all apps can be installed on SD card. For those that can, follow these steps:
1 Install app the normal way (to RAM)
2 In Home screen: press Menu, Settings, Applications, Manage applications.
3 Click the app you want to move to SD and press the Move to SD card button. If it's greyed out, it means the app wasn't designed to be moved.
