J jbg25 Member Dec 5, 2009 #1 My droid is completely frozen. It shows the back ground..but the apps are gone...no buttons work and the time stopped. I cannot get to hard reset by holding the power button...should I pull the battery?
J jbg25 Member Dec 5, 2009 #2 nevermind...it came back like 10 seconds after I hit submit. But this scared me. what if it does not recover? do you pull the battery?
