Root help un-brick htc magic via fastboot
guzvabt
i update radio 6.35.10.18 and 1.76.2007 SPL , and recovery-RA-sapphire-v1.7.0G, and now my phone wont start. It's rebooting all time, i can go in to fastboot but i can't do much. Please help me if anyone one knows what to do
What ROM are you using? not all are compatible with that Radio/SPL combination.
gbd
And which hardware is it? Our Magics are more often 32A "H" versions and not "G". If you can get to fastboot you should be able to flash the proper version.
You actually need to use the Hero version of Amon_Ra recovery with that Radio/SPL combination.
32A users with SPL 1.76.x should flash the Hero version!
Check out Amon_Ra's thread for the HTC Magice over at XDA. The quote from above is from the very first post.
[Recovery] [32A & 32B] [16-May-2010] RA-sapphire-v1.7.0 - xda-developers
Thank you guys for advice, but I failed to settle phone, so I took an official service for repair, more luck next time. Thanks again.
