Help un-bricking?
D
Deleted User
Guest
This post is actually for a co-worker, he used Z4Root to root his phone, then was using Gemini App Manager to freeze the US Cellular bloatware, he restarted the phone now he gets TwLauncher has stopped responding, and locks up, if you dismiss the popup it keeps coming back against a balck screen. I booted it into CWMod and wiped cache and did a Fatory Reset, booted back up, looked stock, same error message. I'm assuming the best thing to do now is to use Odin? and flash a stock rom on there? Problem one.....I have no experience with Odin and problem two.....I don't know where to find a stock Rom for the Samsung Galaxy S, he knows it wasn't running Froyo, but we don't know exactly which version he had....
Thanks in advance....
