血刃战神
(Translated from CHinese by Google Translate)
First picture
Use the command "fastboot flash recovery xx.img" to flash into recovery, an error "partition'recovery' not support flash" is reported
Literally, the partition "recovery" does not support flashing
What's going on
(Attached, the model BOWAY U7, a miscellaneous brand machine, has been down, and there is no unofficial rom supported, so any software based on the model to find the rom flashing machine will not work, this is to flash the rec of other models)
(in Chinese,中文原帖)
【求助】无法刷入Recovery
先上图
用命令fastboot flash recovery xx.img刷热recovery,报错partition 'recovery' not support flash
字面意思的话分区“recovery”不支持刷入
这是肿么回事
(另附,机型邦华U7,杂牌机,已经倒了,没有任何支持的非官方rom,所以任何基于机型查找rom刷机的软件都必不灵,这个是在刷其他机型的rec)
First picture
What's going on
(in Chinese,中文原帖)
【求助】无法刷入Recovery
先上图
这是肿么回事
