loudersoft
Well, it happened -- I bricked my Optimus C getting caught in an endless loop. To get out of this problem (following instructions in this thread) I used the provided Optimus M rom with LGNPST to get the phone unbricked.
However, nothing is working -- I can't seem to get the PLS correct, it doesn't have the proper MEID of the phone and, consequently, I'm connected to the Cricket network but it's not recognizing me.
After unbricking using the Optimus M method, I did the following:
What do you recommend I do in order to get my phone back to a working state? The Optimus M rom got me there, but basically destroyed all usage of the phone beyond a certain point.
Possibilities:
a) find a way to get the correct MEID / MIN / MDN onto the phone and verify it's using the correct network
b) flash back to stock using the proper BIN / DLL files for an Optimus C instead of Optimus M
Suggestions and help appreciated & thanks!
- used the KP500 method to restore the phone to stock
- rooted the phone with Gingerbreak
- Installed the latest ClockworkMod Recovery
- Installed the latest CM7 build
Possibilities:
