Root help updating please!
I'm on a rooted c771 stuck at M100 build. I tried to update using InnoPath update. Package downloads but fails on install and reboots every time. Trying to eventually update to 150 and flash new ROM. I have the m130 to m150 downloaded from wilster. Any ideas on how to get to M130?
Exact message:
ip_previous_update_failed
Reinstalled all bloatware (except the NFL app; I didn't back that one up...) nothing. Can't remove xbin system folder. Did factory reset. Nothing. What do I do here? Anyone?
I can help you with this problem. There are three ways we can go about fixing this, int the order of what should be tried first:
1. Unroot and update - we can use my casio auto root tool to unroot, then try to update, and if sucessfull, we can root again.
2. Update while rooted - we can use the tool above to update while you are rooted.
3. Screw it and put M150 on - make an M100 FULL backup and then put the M150 Rom on. This would be as a last resort. Actaully you should make a full backup before trying any of these.
Let me know which one you want to try. I ask that before we try this could you please find and attach the m100 update to your reply. the file should look something like ipth_package.bin.
