How did you try to flash the boot.img? With this phone, because it currently has no s-off, you have to do it with cmd on the pc. Fastboot flash boot boot.img is the command.
But here is the more important question. Are you trying to flash a custom ROM or just a kernel? It has to be compatible with your ROM or it will not boot, or get caught in a bootloop. Also, the OTA with this phone will also cause a bootloop when using ANY custom ROM. If you did the OTA, you'll need to run the RUU for your phone and start over. Fortunately this site has wonderful walkthoughs for this kind of thing. I'll try to help you where I can.
