Help! Vaulty Deleted my video!!
ZK686
Hey guys, I'm new here!! Looking for some help!!
I have the free Vaulty app for my Droid Incredible.
After I updated it, a bunch of my files disappeared???
WTF???
How can I get them back!!
They were extremely important to me!!!
I haven't tried plugging my phone into the computer yet, but I tried looking for them in Astro I didn't find anything. I'm so bummed!!
WTF???
Could be that the update created a new "vault" folder. If you look at your sd card, you should see a vault folder in /DCIM and in that folder there would be all your media with a .txt extension. Hardly secure, but clever.
How would I get to that?
I can't find anything under "SD & phone storage" on my Incredible??
You should be able to see the dcim folder in astro...open it and take a look. If you dont find it there I doubt it'll magically pop up on the computer(which sees the same folders) If it truly is gone from the sd card then you're outta luck. I think you just arent looking in the right place. Go check all the sd card folders.
There should be a file on your SD called "Vault2". That is where Vaulty puts the media it is hiding from the gallery.
Ugh..it's not in there.
I just downloaded Astro and wen into the "Vault2" folder under dcim and it's gone!!
WTF!!! how can it just delete itself like that?
All I did was install the update it had for Vaulty, and it literally deleted like five files, but all the rest weren't touched??
WTF????
Dude that sucks... it's supposed to hide your videos from your girlfriend, not from you! :D
Did you ever solve this problem? Did the developer ever answer you? Seems like they have a problem between "hiding" your videos and then finding them again.
I haven't solved this problem, and I'm totally bummed.
I've emailed the developer and messaged him on here too.
I don't know what to do at this point, is there a better, more reliable free app than Vaulty?
Thanks.
I've had good luck (so far, knock on wood) with QuickPic. It just puts a .nomedia file in the folder to hide things, but that's more than the default gallery did. Again, not very secure but it works.
hey BRO..HI....
MY SELF rahul here bro i have installed vaulty in my phone and its deleted and also my all photos got deleted which i saved in vaulty..but there is an thumbnail of my images in SD CARD/DCIM/VAULTY2 But bro. when i am opening them they are not opening in their original path can u please help me that how can i get my photos back they are important to me ....please i vll be very very thnakfull to u ...replly me here aur mail me the solution on rahulluvcherryu@gmail.com:o:o:o:o
