Hi, I have an Eken GC10X tablet, and I was attempting to swap my external SD with my internal SD so I can have more room to download stuff. I followed a video called :
MEMORY SWAPPING: Changing Internal SD to External SD in Funbook Infinity P275
Sorry, I cant the link, but its on youtube just type that in.
Upon restarting my tablet, I went to settings and clicked on storage to see if it worked. However, once I clicked on storage, the settings immediately crashed, and a message popped up saying: "unfortunately, settings has stopped". I then went to the camera, and immediately it crashed as well stating: "no external storage available". My external SD card is in the slot. Thus, my tablet is not recognizing it. I even tried hooking my tablet up to my computer and nothing shows up. I have tried a factory reset, and it did not solve this issue.
I was able to download apps so I went back and downloaded the ES File Explorer app. Upon installing it I went to go check the volld.fstab file. I went there and rather than displaying the normal text that is usually seen in that file it displayed this:
Failed to open file (java.io.IOException
at com.estrongs.android.pop.cupcake.app.bt.run(Unknown Source)
at java.lang.Thread.Run(Thread.java:856)
I have no idea how this happened. Also my tablet is running on jelly bean 4.2.2 Is there a way I can just re-install android? Possibly through recovery mode? Please help!!!
