do you have a rom back up? If you do you can try and restore a backup you have.
I think the best thing is find the stock rom for your phone and put it on the SD card. Flash it and see if it works. I think it should. I don't see why not.
Right....then you would need an SD card reader I guess...unless you have another phone lying around that can serve as card reader.how can i get stuff on my SD I can't even turn on my phone. I can boot into hboot and recovery but when I try to actually turn the phone on it just stays on the white boot screen and doesnt boot up. Please explain, thanks
mordechai can still flash a stock HTC ROM using Procedure 3 of this guide through the USB cable:Right....then you would need an SD card reader I guess...unless you have another phone lying around that can serve as card reader.
[GUIDE]How to update HTC Wildfire S/Marvel/A510e/GSM to Software Version 2.3.5
mordechai, just make sure you use an RUU for your MetroPCS phone and NOT the one in the guide which is for Marvel / A510e. But the procedure for manually flashing the ROM is the same. Check out Football's ROM collection (link in the guide) and grab RUU​_Marvel​_C_MetroPCS​_US_1​.05.1550​.00_Radio​_0.94​.00.101​...
