HELP!!!! what does this mean
measly69
<?xml version='1.0' encoding='UTF-8' standalone='yes' ?>
<SharingAccessibilitySettings Version="1.0" Platform="6.0.1" ModelNumber="SM-G925W8">
<assistant_menu_pad_size>1</assistant_menu_pad_size>
<direct_access_magnifier>0</direct_access_magnifier>
<all_sound_off>0</all_sound_off>
<speak_password>0</speak_password>
<accessibility_captioning_locale></accessibility_captioning_locale>
<direct_s_talkback>0</direct_s_talkback>
<hover_zoom_value>1</hover_zoom_value>
<direct_greyscale>0</direct_greyscale>
<accessibility_magnifier>0</accessibility_magnifier>
<time_key_selectable>0</time_key_selectable>
<access_control_keyboard_block>0</access_control_keyboard_block>
<sound_balance>50</sound_balance>
<accessibility_display_inversion_enabled>0</accessibility_display_inversion_enabled>
<VIB_NOTIFICATION_MAGNITUDE>0</VIB_NOTIFICATION_MAGNITUDE>
<rapid_key_input>0</rapid_key_input>
<assistant_menu>0</assistant_menu>
<accessibility_enabled>0</accessibility_enabled>
<face_smart_scroll>0</face_smart_scroll>
<access_control_use>0</access_control_use>
<hearing_aid>0</hearing_aid>
<mono_audio_db>0</mono_audio_db>
<accessibility_captioning_font_scale>1.0</accessibility_captioning_font_scale>
<accessibility_captioning_edge_type>0</accessibility_captioning_edge_type>
<smart_scroll_visual_feedback_icon>0</smart_scroll_visual_feedback_icon>
<greyscale_mode>0</greyscale_mode>
<easy_interaction>0</easy_interaction>
<direct_negative>0</direct_negative>
<direct_access>0</direct_access>
<switch_access_key>0</switch_access_key>
<direct_accessibility>0</direct_accessibility>
<accessibility_script_injection>0</accessibility_script_injection>
<accessibility_captioning_window_color>255</accessibility_captioning_window_color>
<color_blind_test>0</color_blind_test>
<show_button_background>0</show_button_background>
<notification_reminder_led_indicator>0</notification_reminder_led_indicator>
<answering_accessibility_tapping>0</answering_accessibility_tapping>
<assistant_menu_pointer_speed>2</assistant_menu_pointer_speed>
<direct_talkback>0</direct_talkback>
<color_blind_cvdseverity>0.0</color_blind_cvdseverity>
<color_blind>0</color_blind>
<access_control_time_set_min>0</access_control_time_set_min>
<hover_zoom_magnifier_size>0</hover_zoom_magnifier_size>
<rapid_key_input_menu_checked>0</rapid_key_input_menu_checked>
<lcd_curtain>0</lcd_curtain>
<smart_scroll_sensitivity>0</smart_scroll_sensitivity>
<incall_power_button_behavior>1</incall_power_button_behavior>
<air_motion_wake_up>0</air_motion_wake_up>
<audio_balance>50</audio_balance>
<high_contrast_keyboard>0</high_contrast_keyboard>
<accessibility_captioning_edge_color>-16777216</accessibility_captioning_edge_color>
<notification_reminder_vibrate>0</notification_reminder_vibrate>
<color_blind_cvdtype>3</color_blind_cvdtype>
<high_text_contrast_enabled>0</high_text_contrast_enabled>
<galaxy_talkback>0</galaxy_talkback>
<accessibility_sec_captioning_enabled>0</accessibility_sec_captioning_enabled>
<accessibility_captioning_foreground_color>-1</accessibility_captioning_foreground_color>
<direct_color_adjustment>0</direct_color_adjustment>
<haptic_feedback_enabled>1</haptic_feedback_enabled>
<accessibility_display_daltonizer_enabled>0</accessibility_display_daltonizer_enabled>
<air_motion_call_accept>0</air_motion_call_accept>
<smart_scroll>0</smart_scroll>
<accessibility_captioning_typeface></accessibility_captioning_typeface>
<enable_accessibility_global_gesture_enabled>0</enable_accessibility_global_gesture_enabled>
<flash_notification>0</flash_notification>
<high_contrast>0</high_contrast>
<tts_engine>com.samsung.SMT</tts_engine>
<access_control_volume_button>1</access_control_volume_button>
<anykey_mode>0</anykey_mode>
<accessiblity_font_switch>0</accessiblity_font_switch>
<assistant_menu_pointer_size>0</assistant_menu_pointer_size>
<access_control_time_set_hour>0</access_control_time_set_hour>
<direct_universal_switch>0</direct_universal_switch>
<accessibility_display_daltonizer>0</accessibility_display_daltonizer>
<assistant_menu_dominant_hand_type>1</assistant_menu_dominant_hand_type>
<tts_default_rate>60</tts_default_rate>
<accessibility_captioning_enabled>0</accessibility_captioning_enabled>
<time_key>0</time_key>
<voice_input_control_incomming_calls>0</voice_input_control_incomming_calls>
<notification_reminder_selectable>0</notification_reminder_selectable>
<font_size>2</font_size>
<long_press_timeout>500</long_press_timeout>
<answering_bring_to_ear>0</answering_bring_to_ear>
<notification_reminder>0</notification_reminder>
<accessibility_captioning_background_color>-16777216</accessibility_captioning_background_color>
<color_blind_user_parameter>0.0</color_blind_user_parameter>
<accessibility_captioning_preset>0</accessibility_captioning_preset>
<direct_access_control>0</direct_access_control>
<accessibility_display_magnification_enabled>0</accessibility_display_magnification_enabled>
<access_control_power_button>1</access_control_power_button>
</SharingAccessibilitySettings>
I found this hidden in my phone is it hacked or tapped?
<?xml version='1.0
Where were you digging into when you found that?
It seems to be a shareable file representing your accessibility settings whose aim would be to transfer the file to another phone so that the settings get copied. For sure it is not a virus but a system file.
