Help wife thinks I’m texting others, bc of history
tlb1969
I need help…galaxy a53, shows
Used com.android.server.telecom,
Used com.samsung.android.incallui
Used com.samsung.android.dialer
Used com.samsung.android.app.contacts
Samsung My Files
Samsung One UI Home
What does this mean, accused of sending messages and texts
Only supposed to use google said doesn’t use Samsung..
We need answers, please help
Need help saying this means I use, Samsung to hide things and google for family
The Google history detail, has me using multiple apps
Samsung My Files
Samsung One UI Home
ok lets break this down:
1. used.com.android.server.telecom
this just means that the phone was used for telephone related functions. it does not mean necessarily that a phone call was made:What does used.com.android.server.telecom mean? - Quora.
2.used.com.samsung.android.incallui
this is used for managing phone calls and that is whether it is receiving or making a phone call....https://www.androidphonesoft.com/blog/what-is-com-samsung-android-incallui/
3.used. com.samsung.android.dialer
well that is the phone's dialer
4.used.com.samsung.android.app.contacts
and this is for your contacts
these are all normalk functions of the phone.
Used com.samsung.android.app.contacts, I use google but this comes on my detail, do they work together
any time you access your contacts this will pop up.
honestly nothing here speaks that you are doing anything wrong. it just shows that you use your phone. it does not show that you are texting anyone.
Your wife prohibits you from sending people text messages? Is that what you're telling us? Unless you've done something really really bad in the past that involved text messages (and maybe even if you have), that hardly sounds like a reasonable demand. It sounds like she's trying to cut you off from other people, from your support network, so as to control you.
I'm sorry to say: I don't think there's a technical solution to your problem. If someone is this controlling, don't expect even ironclad proof that you're not sending text messages to help.
Tell your wife everything is fine.
In fact, just let her keep it and you can ask for permission to use it on a "as needed basis".
Problem solved...
Can anyone tell
Me what the Samsung android dialer is and the events that took place
And in-call UI is what displays during a phone call, with the little hangup, mute, add call, hold buttons.
Gee I'm glad I ain't married. That way if my girl was giving me the business like that, I'd just walk. Divorce, on the other hand, involves a ton of heartache.
I can tell you that the last shot shows 2 instances of "used Messages by Google", which is the text message app. That doesn't tell us whether you sent texts or looked at texts that were received at that time, or looked at old texts, just that the app was active at those times. Of course if you have an itemised phone bill that might show when you send messages and to who, so if you need to "prove" that you weren't then that might be the better way to do it.
I don't know whether the "details" link would provide more information, because I don't allow Google to keep a history of my app usage (too intrusive for my tastes).
I don't know what you mean by "only supposed to use Google": you have a Samsung android phone, so some of the system apps will be "Samsung" apps, some will be "Google" apps. But when it comes to text messages it makes no difference what app you use, a text is a text whatever app you use, and you can swap between apps and see the same texts.
(And obviously I don't know the background, but this does all sound very controlling).
What kind of app even shows usage history anyway? That sounds like the kind of thing a parent would place on a child's phone, just in case they were playing Angry Birds during the time they should be studying...
