Help with 7 home pages
GAmbrose
I accidently dragged the default mail tab to the remove button (first screen on the left of the homepage) and now I can't figure out how to get it back.
If I hold down the screen and select the mail widget, it isn't the same.
Id did it yesterday with my Favorites screen (first screen to the right of the homepage) and couldn't work out how to get that back either so I ended up doing a Factory reset.
go to add> widget> mail, then when it shows the format, swipe left to get the email list view
is this what you are after?
