im no dev so i would be lost trying to compile a recovery for the note 8.0. we have root now so a recovery would be nice to. ill donate to any dev that can get twrp or cwm ported over for us.
This version of CWM recovery works. Before you flash it with Odin make sure you uncheck "auto reboot". When it is finished flashing, you need to turn off the device and boot into recovery, once back into recovery you then select to reboot, it will ask you if you want it to be permanent or something like that, select yes or else it will not stick and the next time you try to boot into recovery it will be the stock recovery. If you read the thread I am sure it is explained better.
