Help with Adobe Flash
Tedit
Hello everyone, I just got an EPad with Android 2.2 and I am having and when I try to go and view some videos (Comcast on Demmand) it tells me that I need Adobe flash to be able to view. can someone tell me how can i get that flash is requesting, and how to down loaded. when i look in hre i found an Adobe Reader, will that one help me and how can I find the down load because i can read all the information on it and that is free where i dont seem to find the download function.
Thanks
Welcome to the Android Forums!
The ePad is one of many Chinese knockoff tablets. If it supports the Android Market you might want to check there to see if you have access to the Adobe Flash app. If you don't then getting flash onto your mid might present some challenges.
The Adobe reader app is actually for viewing Adobe PDF documents...
