help with android gingerbread
507laura
just got it today, had it working great, then I messed up my Wi-Fi. I set up the WPS PBC and I cannot undo it, so my Wi-Fi will not work. I have tried to reset it and restore settings, any other ideas on how to undo this?
iMito Android OS 2.3 Gingerbread
thanks
WPS is Wifi Protected Setup, right? You should be able to long press on the wifi router you're trying to connect to and "Forget Network" on it. Then try to connect again. If that's what you did, you can always factory reset the thing, seeing how it's brand new.
Go to Settings > SD & Phone storage > Factory data reset. Acknowledge that you know it's going to wipe the device clean and let it reset and reboot.
