Help with app drawer please?
hello,
I have recently bought a Galaxy Note 2, and am having a little trouble with a small blue tab that is appearing on the screen. The tab is full of apps which is handy, but the problem is it is open over everything. It opens over every app, videos, games, menus.... just everything, and i dont want it there. When i hold down on it, all i get is the option to move it somewhere else on the screen, i cant actually remove it :(
Does anybody know how i can get rid of it?
I have my phone running with Go Launcher aswell if that is any help :)
Thanks.
Its not related to Go Launcher, since it appears over a game. The Note two has extra features not found on other phones, even more features than an S3. Its probably something in the main phone settings.
Did you figure out what was causing this? My brother has the Note II and can't remove it.
Thanks in advance.
Fiddling around a Note2 they had in display, that sort of looks like the "airview" tab they were talking about in the demo. Try a long press of the back button.
I believe it's what holds your apps that will enable you to go split screen which is why it's only found on the Note 2.
As said, I think holding down the back button enables/disables it :)
