help with astro file manager
i recently downloaded astro file manager but when i opened it up it showed no files in any of the folders. is there something i need to do for astro to sync all the files.
Try tapping the Home button, it should bring you to the root directory. If not under settings you can change where the home button takes you.
Not that I'd expect a different result, but Filego is an excellent file manager. If you have no luck there, try mounting it to a PC and see if you still come up empty.
I had the same issue but simply disconnected the usb cable from the phone and the computer and Wallaaa everthing worked fine.
