linsalata28
I'm sorry i asked this question in the thread but thought I might get help here faster.
I have the LG L70 ms323
It was rooted using kingroot then switched to SuperSU.
I installed busybox using busybox installer.
I've been using Apps2SD with a 1.5gb ext4 partition but have been getting a few errors with it.
I want to try CM 12.1 or 13 but need to unlock the bootloader first.
Someone please help?
TIA!
I,m getting this error in the command window.
Bootloader Unlock For The LG L70 Part 1
====================By: Android Addict and junkie2100 ==================
Make sure that USB Debugging is enabled,
and
all drivers are installed
ECHO is off.
==============================Disclaimer==============================
I am not responsible for anything that may or may not happen to your
phone. By using this script, you are taking full responsibility of your device.
=============================Other credits============================
Android Addict, junkie2100, Cheetopocalypse, biggiephil, bobdamnit, LoneStar, and PlayfulGod.
[*] Moving laf.img to sdcard/Download folder
[*] Moving laf.img to computer just in case
remote object '/sdcard/Download/laf.img' does not exist
[*] Now going to zero out the laf partition
[*] laf partition complete!!!
[*] Proceed to part 2 of my guide now!!!
laf partition script
========By: Android Addict, junkie2100, Cheetopocalypse, biggiephil, bobdamnit, LoneStar, and PlayfulGod========
ECHO is off.
ECHO is off.
I still cant get enter into fastboot.
TIA!
and
ECHO is off.
ECHO is off.
ECHO is off.
