Hi everyone, This happend to me one time so i was ssearching the internet like crazy.
So i learn how to put my admire like out of the box with this simple steps.
First Download this files
Return to Stock Admire Samsung - Download - 4shared - carlos Belardo
Steps..
2. Put ur phone into download mode.
Turn off phone
Plug usb cable to ur computer only.
Hold down camera button and then connect the usb cable to the phone
A screen will appear saying your about to enter download mode, press volume up and acpet.
(Make sure drivers are installed on computer)
3 Open the File Named Odin multidownloader
4 Find where it says Select OPS. Hit OPS Button and load the file named SCHR720.ops
5 Find Where it says Select Integrated Package and hit the button that says One Package and load the file named SCHR720_EH02_PDA.
6 Is the Final Step Press The Button Named
Start And it will start to flash the Original Firmware and ur phone will reoot automaticly and Wallahh!!! like out of the box..
Any questions!
viequense@gmail.com
Make sure you have drivers installed and winrar or some like that to extract the files, if you follow my instructions everybody should be fine with this and it only takes like 3 minutes. Good Luck!
