Hey I have a superpad that I believe is unfixable. After trying to reflash using iuw1.2 the screen now stays black when powered and the light changes to blue. i tried using the built in factory reset and nothing works. Now I cant get my pc to find the device.
First things first... what type of flytouch 3 / super pad 2 or you using?
Can you remember what model it is?
There are mainly 2 big kinds namely:
The DISCO 10
And
The P041...
What happens when you try to hold down the menu button and (keep pressing down the menu button) hold down the power button simultaneously for about 5 seconds???
Tell me what happens all right buddy?
Don't panic... if push comes to shove I will have to show you how to open up the tablet and remove the internal Micro SD card that should fix it okay?
Thanks so much for the speedy reply. not sure of type as i got it off Cl and from when I 1st got it after going to the desktop I would get not resounding from any app. then I reflashed and well you know the rest. the box that it cam in says SuperPad III. power light, charging light all come on but nothing i press will get my pc to conect to it like before the flash. what steps are there to removing the internal sd? and then what?
heres a little more info on what its doing. I press power button blue light turns on. screen blank and nothing happends. I hold power button for 5 sec and power light cuts off. if i press and hold power and menu button to conect it to my pc the pc doesnt see it. no sounds or display on screen. if i press th small reset button on bottom of device it will turn off the blue light but when i press power the blue light coms back on.
i have a super pad 3 its not rooted or anything, all stock everything. I HAVNT EVEN TRIED TO DO ANYTHING TO IT AT ALL.. the battery died lastnight and screen has been black since... sombody pleaseeeeee help!! i've tried every button combo ever invented and the charging light comes on and even went from red to green (showing its fully charged) PLEASE HELP!
