JesseKnows
Member
The native snooze in the Valiant is sub-helpful: if I did not attend to it, it does not buzz again. I only found one way to get a second snooze, which is to wake the phone and go to the calendar item and set another snooze.
Before the Valiant I used a T-Mobile Samsung Galaxy S 4G (Android 2.3). It came with great calendar alarm snoozing facility, which I believe is the app https://play.google.com/store/apps/details?id=com.bitfire.development.calendarsnooze (from memory, Id' say the screen shots look identical). The Samsung kept buzzing if ignored.
I installed this app on the Valiant, and it seems to do nothing. I never saw any alert from it, even after a reinstall and some poking into the settings.
I sent an email to the app maker and did not receive a reply. Their app store entry is 2 years old.
Any thoughts? I need the calendar to notify more than once on upcoming events.
