Root Help with Cyanogen Mod
So I rooted my phone and I installed CyanogenMod on my Optimus 3D. Everything went well but after the install, it said I had no service. I was not able to make phone calls, text, or use data at all. But before this, I had full bars etc. I don't know if it matters, I have V21d for the firmware on my phone.
Please help. I've been looking all over the googlez to see what the problem is!:argh:
Often times I lose all service when I flash a new ROM. Have you tried a simple reboot? That usually does the trick for me. If not, I'd make a backup and try a factory reset.
Also, welcome to the forums!
Moved to the root section.
Welcome to the forums Androidswag!!
You might want to do a Sim card pull too. I know sometimes that helps.
