Help with date on Samsung Infuse
suegottey
When I purchased my phone there was a date on the top left corner of the phone.
It is now gone and I can't get it back, any suggestions?
Welcome to Android Forums.
Sounds like you might have had a date widget and inadvertently deleted it. Try long-pressing on the home screen (touch and hold for 2 seconds or longer) and select widgets from the pop-up menu. See if you have a date widget that is what you are looking for.
If all you want is the date and time you could look at the Minimalistic Text app.
