Hi All,
Can not figured out yet how to align dialog title to the right.
My application is Hebrew based (right to left) and i struggled and did notn
found an appropriate reference on how to right align dialog title to the right.
In short i show this dialog when clicking on image view.
Here is the dialog layout:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
androidrientation="vertical"
android:textSize="50px">
<ScrollView android:id="@+id/ScrollView01"
android:layout_width="wrap_content"
android:layout_below="@+id/ImageView01"
android:layout_height="200px">
<TextView android:text="@+id/TextView01"
android:id="@+id/TextView01"
android:layout_width="300dp"
android:layout_height="wrap_content"
android:textSize = "15sp"/>
</ScrollView>
<Button android:id="@+id/Button01"
android:layout_below="@id/ScrollView01"
android:layout_width="100dp"
android:layout_centerHorizontal="true"
android:text="סגור" />
</RelativeLayout>
Here is the code:
dialog.setContentView(R.layout.maindialog);
dialog.setTitle("THIS IS ONLY TEST");
dialog.setCancelable(true);
dialog.show();
//set up text
txt = (TextView)dialog.findViewById(R.id.TextView01);
btn=(Button) dialog.findViewById(R.id.Button01);
btn.setOnClickListener(new OnClickListener() {
public void onClick(View v) {
dialog.dismiss();
txt.setText("This is only text");
The problem is that "THIS IS ONLY TEST" is aligned to the left.
Any Ideas??
10X
RBHDROID
</ScrollView>
</RelativeLayout>
Here is the code:
dialog.show();
//set up text
dialog.dismiss();
Any Ideas??
10X
RBHDROID
