Help with esfilexplorer...
mac1961
I have a Sony Tablet S with esfileexplorer installed. I have successfully connected via LAN and I am able to access files from my computer, and move them to the local disk on the tablet and edit them. However they are saved in the local disk, and when I try to send it back I get an error message saying that the file cannot be moved. consequently I have to email the file back to myself so I ccan put the edited version on the PC. Basically I cannot move any files from the tablet to the pc as I have tried. Any help on this? Thank you
I just copied a file from my local storage to the LAN using ES File Explorer, and then used the "Move to" option to move the file to the same location. I got a warning that the file exits, tapped OK to overwrite it, and it successfully moved the file.
Are you using something other than the "Move to" option? Are you using the same username on both the PC and ES File Explorer?
