reinbeau
Klaatu barada nikto
Please help an old lady learn. I am baffled with the file structure on this phone. I don't get it.
When I start up any file manager (I've got Astro and Root Explorer), the very top is / . Then below that is:
.info (folder)
cache (folder)
config(folder)
data (folder)
dbdata (folder)
default (file)
dev (folder)
efs (folder)
etc (folder)
fota (file)
init (file)
init (file)
init.smdkc110
init.smdkc110
lib (folder)
lpm (file)
mnt (folder)
proc (folder)
recovery (file)
res (folder)
sbin (folder)
sdcard (folder)
sqlite_stmt_journals (folder)
sys (folder)
system (folder)
system (file)
tmp (folder)
userdata (folder)
void (file)
If I click on /sdcard, I'm presented with many folders that look like app folders, they contain data (Ringtones contains the ringtones I've downloaded and set for use). I'm thinking /sdcard is my internal sd card. But there's one file folder in that listing that says 'sd'. When I click on it, I'm pretty sure I'm on my external sd card, the path is /sdcard/sd. That is totally empty, except for one zip file I copied there so I could pull it out and transfer it to my computer (I've got a little converter that I slide my external sd card into). It was dumb luck that I picked the 'sd' folder, I wasn't sure where I was at all.
So, this post has been an exploration, so to speak, but my problem is, I have no idea how to make programs on my Captivate utilize the external card. I've tried, but obviously I'm missing something.
I've got Titanium Backup. I thought it was writing to the external card, obviously I'm wrong. Could someone use that program as an example and tell me, step by step, how to make TB store my data on my external card? Maybe then I'll be able to make other apps 'talk' to that card.
I've tried to change my backup directory to /sd/sdcard/Titanium Backup, now TB says Backup directory: not available. :::sigh:::
Ok, figured that one out - the path is only /sdcard/TitaniumBackup. So now my apps are backed up to the external, how/should I delete the backups from the internal card?
I guess this is a stream of consciousness exploration here, I'm still open to any help or insight you can offer!
.info (folder)
cache (folder)
config(folder)
data (folder)
dbdata (folder)
I've been in dbdata to enable sideloading - so I'm not totally hopeless!!
dev (folder)
efs (folder)
etc (folder)
fota (file)
init (file)
init (file)
init.smdkc110
init.smdkc110
lib (folder)
lpm (file)
mnt (folder)
proc (folder)
recovery (file)
res (folder)
sbin (folder)
sdcard (folder)
sys (folder)
system (folder)
system (file)
tmp (folder)
userdata (folder)
void (file)
