Root Help with flashing Kernel in CWM.
S pen
I have installed a GB rom on my Galaxy Note, and proceeded to try and install "Hydracore" kernel and it didn't work. Now every time I try to install even different kernels they install successfully, but when I reboot the phone gets stuck in this very light dim screen with random black blotches on it.:confused: The dim screen is a very light shade of black, and you can't tell the screen is even on if there is any light in the room. If you are in a completely dark room you can see that the screen is lit up with a very dark creamy/pink screen with black spots all over it. What the hell is this?
I need to install a "safe" kernel so that I can install a decent rom to use on my phone, so any help on this would be really appreciated.
Hydracore is for ics.You cant flash it on gb
All gb kernels are safe..so simply root your phone and flash any rom of your wish
