matt268uk
Hi Everybody,
Right my problem is i cant seem to flash a new rom,i'm not totally up on all of this stuff but have read and read this forum as well as other places,i have successfully installed the revolutionary system and i have s off.also if i look in my apps i have one thats super user, so this is what i do, i have a new micro SD card thats formatted,i find a rom which had suddenenly become almost impossible and download it,i then connect connect my phone and copy the zipped rom file straight to the sd card.I then unplug the phone turn it off and pull the battery.then holding down the volume key and pressing the power turn it back on,i do a back up then factory wip,dalvik casche wipe and any other wipe,then i install the rom,finally it says reboot system, so i go ahead and reboot and it just gets stuck in a cycle, i have tried lots of roms over time,they seem to install ok but jjust won't finally boot up,the most recent was revolution easter edition,this one got almost to the point of booting up ,i had the signal strength meter and battery and 3g logos but none of the buttons would work and the touch screen was non responsive.so it cant be a certain rom cos i've tried lots,its something i'm doing....can anybody possibly help me,but using easy instructions,i'd be very greatful as i cant install any updates or apps at present as i've rum out of phone memory.thankyou in advance Matt.
