XxAP0STLExX
Hey guys. I've been looking around all over for info on the problem with my app. Nothing I found was a concrete answer. here's the problem. I made an app that works really well except it force closes when I hit the back button to finish activity and then start another of the same activity as before. It force closes once in a while when I do this, throwing a log cat error that says out of memory, pointing to where I fill my bitmap cache. There's two reasons im thinking it would be doing this. 1) My bitmap factory is having a problem or 2) I have the context of my activity stored as a variable so I can close activity and that is too much memory. I'm using a panel, which also may add to the problem. Also, another phone can't even start the activity the first time. Any help would be greatly appreciated. This is only problem on app.
