Help with Gameboid
obsidianwings
Hi,
I'm new to this kind of thing, so if anyone could please help me it would be much appreciated.
I have gameboid on mg LG P500, I have loaded the BIOS, but 2/3 games I have say "Load ROM failed" when I click on them. What am I doing wrong?
Hi,
maybe is the wrong bios u got the roms on the download folder?
Hey, appreciate your quick reply, but got some more working, so I think just the 2 ROMs that weren't working aren't good ones?
I do have some slight sound crackle though, is this something I can fix in settings? Not to sure which settings might fix it if any. Am happy to put up with it though if its not fixable, its quite minimal :)
It may be that the sound is amplified too much. Turn down the game sound a little. If you can't hear it, then, see if you can fiddle with volume of the emulator and the volume of the phone to the point where you can hear it without the crackle.
Cheers for that :) Seems to be less so once I get further into a game, so maybe a buffering issue? Don't know if thats possible.
Will have a fiddle with the volumes in case I can have it better though.
